Sep 28th, 2026, 11:17am
running Spectre simulation in directory fo my choise (Read 2245 times)
sutapanaki
Mar 04th, 2019, 9:18pm
I would like to temporarily  let simulation started from ADE run in a directory that's different than the default one. I know how to set where to save the results if I run from ADEXL but can't find the right place to set it in ADE-L.
Appreciate your help. Thanks.
Re: running Spectre simulation in directory fo my choise
Reply #1 - Mar 5th, 2019, 10:21pm
Setup->Simulator/Directory/Host will allow you to change the simulation directory root.
sutapanaki
Reply #2 - Mar 7th, 2019, 7:01pm
Thanks, Andrew.
