Hi
I'm working on simulating an ideal delta sigma modulator in hspice and I need to use ideal models for different parts of my circuit. for example I want to simulate the quantizer.va model in hspice for a 3rd level quantizer. I follow the manual for simulating this kind of models in hspice but unfortunately it is not working. I will appreciate if anyone can help me.
the .va and .sp files are attached below and are written too.
Also the problem is that when I simulate the test.sp in hspice nothing happen and the .lis file is empty and no error and other information is shown.
.quantizer.va file:// N-level triggered quantizer (like an ADC followed by a DAC)
// Version 1b, 17 July 03
// Ken Kundert
// Downloaded from The Designer's Guide (
www.designers-guide.org).
// Post any questions to
www.designers-guide.org/Forum`include "disciplines.vams"
module quantizer (out, in, clk);
output out; voltage out;// output
input in; voltage in; // input
input clk; voltage clk; // clock input (edge triggered)
parameter integer levels=2 from [2:inf);// number of quantization levels
parameter real vh = +1; // voltage of highest level
parameter real vl = -1 from (-inf:vh); // voltage of lowest level
parameter real vth = (vh + vl)/2; // threshold voltage of clock
parameter integer dir = +1 from [-1:+1] exclude 0;
// if dir=+1, rising clock edge triggers
// if dir=-1, falling clock edge triggers
parameter real td = 0 from [0:inf); // output delay
parameter real tt = 0 from [0:inf); // output transition time
real quantized, delta;
integer level;
analog begin
@(cross(V(clk) - vth, dir) or initial_step) begin
delta = (vh-vl)/(levels-1);
level = (V(in)-vl)/delta;
if (level < 0)
level = 0;
else if (level >= levels)
level = levels-1;
quantized = level * delta + vl;
V(out) <+ transition( quantized, td, tt );
test.sp file:Title: testing verilog-A
.hdl quantizer.va
.options post=1
VCLK clk 0 pulse 0 1 1f 1f 1f 0.390625u 0.78125u
Vin in 0 SIN 0 1 2k
Xquantizer1 out in clk quantizer levels=3 vh=1 vl=-1 vth =0 dir=1 td=0 tt=0
RL out 0 1meg
.option method=gear post=1
.options delmax=10n
.temp 25
.op
.tran 10n 20m
.end
