Aug 14th, 2024, 11:14am
Model optocoupler NSL-32SR3 (Read 966 times)
Leonardo
Rio de Janeiro, BRAZIL
Jul 08th, 2019, 2:28pm
Hi all
This is my first post in the forum.
I need to model an optocoupler (NSL-32SR3) that reduces its resistance with increasing current. I was able to deduce the mathematical equation from the curve using Excel.
Equation : R = 293,01 * i ^(-0,593)
But since I have little experience in Verilog I do not know how to create an expression that converts the input current to output resistance in the Verilog language.
Below is datasheet´s optocoupler.
Could someone give me some tips?
Thx
Leonardo
Re: Model optocoupler NSL-32SR3
Reply #1 - Jul 12th, 2019, 7:24am
You should look on the paged linked to the "Verilog-AMS" tab above and find a resistor or a controlled source model and learn the basics of writing a Verilog-A model. Start with a simple linear resistor but rename the module to nsl_32sr3 and give it the pin names you want.
