Apr 27th, 2024, 5:10pm
Timer function with tolerance parameter (Read 1378 times)
nthoangga
Jul 24th, 2019, 9:45am
Hi, Here is the timer function documentation:
timer(time[, period][, ttol][, enable])
Parameters
time (real) – time of needed evaluation point
period (real) – period or repetion
ttol (real) – time tolerance
enable (real) – enable
Only 'time' is required, other parameters are optional.
If I want to provide 'ttol' parameter, but don't have a need for 'period', how could I do it?
One idea is just to give a very big value for 'period' (ex. period=10). But is there any other ways around it?
Re: Timer function with tolerance parameter
Reply #1 - Jul 24th, 2019, 11:12am
Don't know for sure, but you might want to try:
timer(1u, ttol(1n))
or
timer(1u,,1n)
Reply #2 - Jul 25th, 2019, 5:11am
It seems like the syntax should be
timer(time [, [period] [, [tol] [, [enable]]]] )
instead of
if null/missing arguments are supported.
Reply #3 - Jul 25th, 2019, 5:13am
Actually, Annex A of the Verilog-AMS Language Reference Manual version 2.4 has:
timer ( analog_expression [ , analog_expression_or_null
[ , constant_expression_or_null [ , analog_expression ] ] ] )
and it's clear that null arguments are allowed (per the syntax - your simulator may not be fully compliant).
nthoangga
Reply #4 - Jul 25th, 2019, 3:26pm
Ken Kundert wrote on Jul 24th, 2019, 11:12am:
timer(1u, ttol(1n))
or
timer(1u,,1n)
Just to confirm the comments above, first method does not work. Second method works.
Reply #5 - Jul 25th, 2019, 4:34pm
Whoops. It should have been:
timer(1u, .ttol(1n))
I was missing the period before ttol. Even then it might not work. I don't know whether named arguments are supported for functions and tasks.
