Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Aug 14
th
, 2024, 1:28pm
Home
Help
Search
Login
Register
PM to admin
Simulators
Circuit Simulators
› Plotting On Resistance of a Bootstrapped Switch
Previous topic
Next topic
Plotting On Resistance of a Bootstrapped Switch (Read 1015 times)
repah
Aug 20
th
, 2019, 6:02pm
How does one plot the on resistance of a bootstrapped switch ?
IP Logged
Re: Plotting On Resistance of a Bootstrapped Switch
Reply #1 -
Aug 26
th
, 2019, 6:51am
You probably want 1/GDS of the transistor. You'll need to provide more information (eg, what simulator?) if you need more help than that.
IP Logged
Reply #2 -
Aug 26
th
, 2019, 12:45pm
Connect one side of switch to DC voltage source. Then connect a current source across the switch with mag=1. Assure the switch is turned on. Perform an fixed-frequency AC analysis while sweeping the voltage of the DC course. Plot the voltage across the switch. The magnitude will equal the switch resistance.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
»» Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
