Sep 26th, 2026, 6:07am
How to get Nyquist plot with VIVA ? (Read 4014 times)
pwm
Sep 14th, 2019, 5:39pm
Using Spectre and VIVA. I need Nyquist plot with real and Imaginary axis to analyze stability. Thanks !
View Profile hoonsk   IP Logged
Re: How to get Nyquist plot with VIVA ?
Reply #1 - Sep 17th, 2019, 3:06am
You can do this by running a stability analysis (stb) in Spectre, and then using the Results Browser go to the "stb" results and picking that the graph type will be either "Polar" or "RealvsImag" rather than "Default" (which is "Rectangular") and then double clicking on the "loopGain" signal within the stb results.
It's probably polar that you want rather than real vs imaginary because that then shows both the unit circle and also the angles - so it's easier to assess the stability that way.
Andrew
pwm
Reply #2 - Sep 17th, 2019, 5:52am
Andrew Beckett wrote on Sep 17th, 2019, 3:06am:
Andrew
Thanks Andrew !
It's strange that I could not find the RealvsImag in the Result Browser, only the Polar is available.
The case I have is strange, the phase margin is >60deg, Gain margin > 15dB and yet I have more than 3 rings in the transient. I don't think it is due to large signal instability i.e. it tripped some comparator. I notice that the Q factor due to the complex pole can be a factor, i.e. the higher the gain-peaking, the worse the ringing it will be. Maybe there's another better way to assess the stability due to the gain-peaking that can be recommended ?
Reply #3 - Sep 22nd, 2019, 5:00am
Which IC version are you using? (the precise number that's in Help->About in any Virtuoso window will help).
Hard to know what your stability issue is without more details.
Andrew
pwm
Reply #4 - Sep 22nd, 2019, 4:34pm
Andrew Beckett wrote on Sep 22nd, 2019, 5:00am:
Andrew
Virtuoso 6.1.7-64b
Reply #5 - Oct 4th, 2019, 6:32am
That's only the first part of the version number - I asked for the entire version number (which is shown on the Help->About form)
If it makes it easier, type in the CIW: getVersion(t)
and then post the result here.
Reply #6 - Oct 4th, 2019, 6:38am
Actually, I just checked in the base release (IC6.1.7-64b.78) and RealVsImag is there - so I'd be surprised if it went missing in a later sub-version.
Here's what it looks like for me in the results browser...
Andrew
