Aug 14th, 2024, 11:44am
adaptive initial transient across corners (Read 905 times)
Horror Vacui
Dresden, Germany
Sep 28th, 2019, 12:00pm
Hi Everyone,
What ways are there to control the initial transient in spectre based on some conditions? I very often face the problem, that the startup or initial transient of a circuit is long and is a strong function of PVT corners or testbench variables, making a sweep across corners and variables extremely time consuming if I have to adjust for the worst case corner. I've used a veriloga block recently, which among other functions also had a similar role and I am wondering whether there are any other ways to address this issue.
Re: adaptive initial transient across corners
Reply #1 - Sep 29th, 2019, 10:58pm
Why is there an initial transient? Did you turn off the DC analysis that starts the transient analysis.
Horror Vacui
Dresden, Germany
Reply #2 - Oct 8th, 2019, 6:49am
In the presence of a large input signal, the DC and the average steady state voltage will differ due to the non-linear device characteristics.
