saigoutham
Hi, I am new to Verilog-A and saw the following model for a Diode in Cadence's AMS reference manual.
module diode (a, c) ; inout a, c ; electrical a, c ; parameter real rs=0, is=1e-14, tf=0, cjo=0, phi=0.7 ; parameter real kf=0, af=1, ef=1 ; analog begin I(a, c) <+ is*(limexp((V(a, c)-rs*I(a, a))/$vt) - 1); I(a, c) <+ white_noise(2* `P_Q * I(a, c)) ; I(a, c) <+ flicker_noise(kf*pow(abs(I(a, c)),af),ef); end endmodule
How to read and understand this line? "I(a, c) <+ white_noise(2* `P_Q * I(a, c)) ;" I see I(a,c) is being used on both left and right side of the assignments. Thank you for the help. Regards, Sai.
