Mar 28th, 2023, 3:55am
Propagation coefficient extraction (Read 1131 times)
Horror Vacui
Dresden, Germany
Nov 20th, 2019, 10:22am
Hi everyone,
I have reached again my limits. I must make an error in interpreting the phase coefficient (the imaginary part of the propagation coefficient). I've got transmission lines, where the A value in the ABCD (or 1,1 index element in the chain matrix) supposed to be as in the attached formula.
Therefore I expect the angle of A to increase linearly with the frequency. Instead of that I see step-like function when I plot my measurement or simulation results. I've attached one - in the next post - based on simulated S-paramters, i.e. there should not be any effect of pads or noise. The only discrepancy should be the not exactly 50Ohm characteristic impedance, but for any practical considerations, it is 50Ohm. The permittivity is also not constant and a function of the frequency, but not in this way.
Am I wrong somewhere? Is the attached plot normal?
« Last Edit: Nov 20th, 2019, 11:47am by Horror Vacui »
Horror Vacui
Dresden, Germany
Re: Propagation constant extraction
Reply #1 - Nov 20th, 2019, 10:24am
And the angle vs freq plot
