Jul 27th, 2024, 4:50am
Noise options when simulating with Spectre and ADE-L (Read 1010 times)
vivkr
Nov 27th, 2019, 7:22am
I am a bit puzzled by the behavior of the "NOISE OPTIONS" section found under "Simulator Options" for Spectre when simulating via ADE-L.
One has the option of disabling/enabling noise types and/or contributions from certain instances.
In an example run, I used the above to only enable flicker noise from one of the instances in my design.
The noise summary however still shows me other devices and other noise types, even though the netlist clearly contains statements showing the "noiseon_type" as well as the single selected device under "noiseon_inst".
Anybody knows what these options are actually supposed to be doing?
Vivek
Re: Noise options when simulating with Spectre and ADE-L
Reply #1 - Dec 5th, 2019, 4:17pm
I believe you are referring to the ability to control which noise sources
contribute during transient noise analysis. This is provided as a tool for
debugging transient noise issues.
Since you enabled 1/f noise for a device, you turned off the other contributions
for that device. However, all the other devices are still contributing noise.
For example, you enabled M1 1/f noise, then the results will include the
1/f noise contribution for M1 and the all the other noise source for all the
other devices in the design.
You will need to turn the other noise sources off, if you only want to see
the noise from M1 1/f noise
