Jul 16th, 2024, 1:30am
DAC noise analysis? (Read 1159 times)
Jacki
DAC noise analysis?
Dec 11th, 2019, 1:13am
   When we do the noise shaping, we need a DAC in the feedback loop and add the output of the DAC to the input of the sigma-delta modulator. Most of the time, we focus on the quantization noise in the ADC, but I wonder how about the noise from the DAC since its noise will be added to the input directly. Is it the same as the quantization noise or some other noise also become important.
   Thank you very much for your knowledge and sharing.
Jacki
Re: DAC noise analysis?
Reply #1 - Dec 13th, 2019, 2:41am
I think if there is no excess loop delay, and with an ideal DAC, the DAC will form the original analog signal, and its noise is mostly from DAC like the thermal noise. hence the nonlinearity and excess loop delay are more important for the DAC design.
neoflash
Mixed-Signal
Designer
Reply #2 - Jan 6th, 2020, 9:08am
For SDM, DAC noise analysis is well studied in text books from Temes. Just read it.
