Oct 6th, 2024, 1:54am
Hurry, how to use the netlist-based/spice-based spectrerf simulation. (Read 1633 times)
Jacki
Feb 26th, 2020, 7:14am
   We are spoiled too much by Cadence, now I have no idea how to use the netlist-based/spice-based solution to simulation VCO by using SpectreRF. All of the tutorials from internet is graphic solution, I wonder who can give me an example with the netlist simulation, or any tutorial of the SpectreRF syntax in the netlist?
   Appreciate very much.
Re: Hurry, how to use the netlist-based/spice-based spectrerf simulation.
Reply #1 - Feb 27th, 2020, 12:34am
See listing 1 in Simulating Switched-Capacitor Circuits with Spectre-RF.  Or, if you are into Python and what to see an example of the whole process from generating the netlist, through simulating, to extracting and plotting the waveforms, see Flicker Noise
Frank Wiedmann
Munich, Germany
Reply #2 - Feb 28th, 2020, 3:16am
Hi Ken,
I'm not sure why you changed the name of the voltage source from Vin to Vmod in runPnoise, but it breaks the simulation unless you also change the oprobe statements.
Frank
Reply #3 - Mar 2nd, 2020, 9:47pm
No particular reason other than I think it makes it a bit more obvious what the purpose of the source is. I think I found the problem myself after a day or so and fixed it. Thanks for reporting it.
Frank Wiedmann
Munich, Germany
Reply #4 - Mar 3rd, 2020, 2:37am
The pnoise.scs file still has the problem (which is not a real issue because runPnoise overwrites it).
Reply #5 - Mar 3rd, 2020, 3:17pm
Whoops. Fixed now. Thanks Frank!
