Jul 2nd, 2025, 11:23am
IP3 Simulation of a Sample and Hold Circuit in Spectre (Read 2169 times)
repah
Mar 26th, 2020, 10:32pm
I want to measure the IP3 of a Sample and Hold (clocked) using Cadence Spectre.
What is the best procedure for this ? QPSS or PSS ?
I want to sweep over input voltage.
The circuit diagram is attached.  Just a simple tgate switch with a hold cap clocked at 2GHz, followed by a buffer then another tgate switch and a hold cap.
Input is a 50Mhz sine wave at 5mV.
Do I follow advice in application note - simulating switched capacitor filters on this forum - ie. do QPSS ?  How is this setup for a clock and an rf input, if using QPSS ?
Thank you.
Re: IP3 Simulation of a Sample and Hold Circuit in Spectre
Reply #1 - Mar 27th, 2020, 10:31am
From a simulators perspective, a clocked sample and hold is no different from a mixer where the clock plays the role of the LO.
I recommend you following the instructions in Accurate and Rapid Measurement of IP2 and IP3. See section 7.
repah
Reply #2 - Mar 29th, 2020, 1:34am
Thank you Mr. Kundert.
But this system is clocked, do I use a SINE for my LO (clock port in sampling application) versus a PULSE.
I notice when simulating mixers - the LO is defined as a SINE even though it is a pulse.
Why is this ?
Also following the example in your application note:
My LO is the clocking frequency of the sample and hold, say 50MHz.
My f1 is the input frequency of the sample and hold, say 2GHz.
I use 51MHz as an f2.
In QPSS, I set LO to be large signal and f1 to be moderate.
Then in QPAC I set my f2 to be 51MHz.
I do this, and I don't get a reasonable response, but I used PULSE on my ports for clock/lo and not SINE.
What am I doing wrong ?
Reply #3 - Mar 29th, 2020, 12:30pm
There is no need for the clock/LO to be a sinusoid. The only restriction is that the signal be periodic.
Why is f1 2GHz? Why is f1 a multiple of the clock?
A sample and hold is broad band, so why not simply use harmonic distortion rather that intermodulation distortion?
