Sep 26th, 2026, 3:08pm
SNR and ENOB of a DAC in Cadence Spectre (Read 1138 times)
repah
Apr 19th, 2020, 6:31pm
I am trying to measure the ENOB and SDR / SNDR of a DAC in Cadence Spectre ( I am using old version of Cadence IC5.14).
Its a 10GS/S DAC.
I am inputting a 10GHz clock, 100 MHz 256mV (full scale) sinuosoid into an ideal 8 bit ADC from ahdlLib.  From then it goes into my DAC.
I am running/using PSS, and PSS selects the clock and input sinusoid as large frequency signals with beat frequency of 100MHz, I run with conservative and moderate, 10 harmonics, and no other changes.  It does not converge to a solution.
See settings attached.
OR should I run a transient and just do an FFT on the output.
Can PSS be used for this type of circuit?
Thank you.
What am I doing wrong ?
« Last Edit: Apr 20th, 2020, 11:47am by repah »
