Oct 28th, 2026, 10:04pm
combining PWL and smooth waveforms in one voltage source (Read 2647 times)
sutapanaki
Jun 25th, 2020, 5:46pm
I need to create a verilogA script for a voltage source that combines both PWL and smooth sections of its behavior, like in the attached picture. I can use the transition filter for the PWL part and I think for the smooth part it is best if I use the branch contribution operator <+ only. I don't know how to combine both. Any help will be very appreciated. Thanks.
Re: combining PWL and smooth waveforms in one voltage source
Reply #1 - Jun 26th, 2020, 9:57am
You could use addition or multiplication.  For example:
analog begin
    offset = transition(enable, 0, 10n);
    sine = ampl*sine(6.28*freq*$abstime);
    V(out) <+ offset + sine;
analog begin
    on = transition(enable, 0, 10n);
    sine = on*ampl*sine(6.28*freq*$abstime);
    V(out) <+ sine;
