Mar 30th, 2023, 4:08pm
how to probe a net within a hierarchy (Read 574 times)
matisse
Jul 28th, 2020, 7:10pm
I am trying to implement something like the deepprobe function that is provided by Cadnece, but with veriloga only, as I use HSPICE. The idea is to be able to probe a net in a sub-block without having to pin that net out to the top level.  Right now I have some code like this, but the output just reads some mV and does not track the internal net.
`include "constants.vams"
`include "disciplines.vams"
module deepprobe_ams (out);
output out;
voltage out;
//parameter string hiername = "tbname.I1.I0.c";
analog begin
	V(out) <+ V(xtb.clk10x_h);
a few questions:
  • Can I make a string parameter that can be filled in for the probe path like in deepprobe?
  • should the hierarchical naming be in relation to where the veriloga block is instantiated in the hierarchy or relative to the SPICE deck?
I have consulted the Accellera language reference manual, and have not had any luck.
BTW, I have The Designer's Guide to Verilog AMS book, and I find it is very well written.  Thanks for that.
davidshw
China
Re: how to probe a net within a hierarchy
Reply #1 - Aug 4th, 2020, 5:46pm
as I know Hspice directly support hierarchy node, you can add this statement in the hspice netlist
vprobe1 xtb.clk10x_h  out  0
