Sep 17th, 2026, 5:14am
S-param accuracy issue during Spectre transient simulation of low coupling induc (Read 3091 times)
Aman101
Israel
Aug 04th, 2020, 8:08am
I am simulating a 4 port S-param file of two inductors with weak coupling between them (about -110dB).
First inductor: ports 1-2
Second inductor: ports 3-4
Nport settings: interp=linear, imptrunc=1.0e-6
Frequency: 0 : 100MHz : 300GHz
Simulation is comprised of a voltage source across port 1-2 while measuring voltage across ports 3-4.
Simulation is performed in AC and Transient (setting a pure 1V sinusoidal signal at 14.5GHz).
AC response is very smooth without any strange unexpected artifacts.
Tran response is converged without any blow-up artifacts.
Unfortunately, Tran response is 4 times the AC @ 14.5GHz!!!
I suspect it is originated from Spectre Impulse Response calculation.
Therefore I set the following Nport settings:
imptrunc=1.0e-12
imptrunc=0
datatrunc=0
All did not alter the results much.
When using S-param of stronger coupling between the inductors (-80dB), Tran and AC are identical!
using bbspice only makes things worse...
What are the Spectre settings for most accurate Impulse response?
Thank You.
p.s. I have read the article "7 Habits of Highly Successful S-Parameters" from 2019.
Re: S-param accuracy issue during Spectre transient simulation of low coupling induc
Reply #1 - Aug 9th, 2020, 6:18am
I would suggest contacting Cadence's customer support.
