unaffected
I designed a pierce oscillator oscillating at 25MHz, the figure attached is the stb analysis result, the loop gain is 20dB at 0deg.
I tried everything I can do to start the oscillator. I set the maxstep to 10ps or 100ps, set initial condition of Lm to 1uA or 10uA, errpreset=conservative, integration method is trap or traponly. tighten reltol, vabstol, iabstol, using transisent analysis or hb analysis, at t=0+ the oscillations starts, but then its amplitude becomes smaller and smaller, and the oscillation stops.
My question is: 1. From the loop gain and phase plot in the attached figure, I think this oscillator can oscillate at about 25MHz. Am I right? 2. Why this cystal oscillator cannot sustain oscillation? Is there anything I can do to simulate it correctly?
Thank you very much.
