Dec 13th, 2025, 9:29pm
GCD fill layer in 28nm technology (Read 1786 times)
vlsi_design
Jul 24th, 2022, 6:55pm
Hi, In addition to active, poly and metal fill layers, do I need to do GCD fill layer for a typical 28nm cmos technology? The kit documents do not clearly explain it. What are the additional fill layers needed a typical 28nm cmos technology?
ajithkv
Re: GCD fill layer in 28nm technology
Reply #1 - Jan 26th, 2024, 8:10am
Can you clarify what is the GCD layer, please? Generally dummy fill rule deck will generate all necessary fill layers for a given design.
