A variable is associated with the discrete kernel if it is initialized or if it is assigned a value in an initial block or an always block.
A variable is associated with the continuous kernel if it is assigned a value in the analog block.
A variable with conflicting conflicts is associated with both kernel.
If you want further help, you should show your model.
