Jul 2nd, 2025, 11:43am
pnoise simulation of integrator (Read 1340 times)
yumi
Feb 21st, 2023, 1:08am
1. Before the pnoise simulation, we have to run pss, how should the number of harmonics to be set? Does this value should same as the maximum sideband in pnoise simulation?
2. As article named "Simulating switched - capacitor Filter With SpectreRF" mentioned, we can simulation with unsampledNoise analysis and sampledNoise analysis. In the latest version of spectre, I cannot find these in analysis, how to realize these two simulations? By pnoise or other analysis?
If this can be realized by pnoise, how to set the parameters?
Re: pnoise simulation of integrator
Reply #1 - Feb 21st, 2023, 7:04am
The harmonics parameter in PSS allows you to specify how many harmonics in the output spectrum you need.  If you don't plan to look at the output spectrum, then you would set it zero to avoid wasting time computing the output spectrum.  Spectre allows this.  However, for reasons I have never understood, ADE requires that you provide a non-zero value.  So you would set harmonics=1 to minimize the waste.
The sampled and unsampled noise analyses in the paper were being performed outside of ADE.  They names unsampledNoise and sampledNoise are arbitrary.  I chose them to be descriptive.  What is important is the parameters specified with each analysis.  To perform these analyses in ADE you would would configure the PNoise analysis to perform a sampled noise analysis.  Look for some kind of time-domain noise parameters and ask for one point at the time you select.
yumi
Reply #2 - Feb 21st, 2023, 6:01pm
Thanks for your reply, it helps a lot. Just for confirm, if I want to see the samplednoise (with noise aliased to fs/2), the noisetype should be set as sampled(jitter)?
Reply #3 - Feb 22nd, 2023, 11:46pm
I don't know. I don't recognize that version of the form, and the label seems self contradicting.
smlogan
Boston, MA
Reply #4 - Mar 6th, 2023, 5:01pm
Dear yumi,
I am not sure of your objective, but if you set the noisetype=sampled(jitter), the noise is measured only on the threshold crossing you define in the GUI - the remaining portion of the waveform is not used.With the radio button selection you show ("Sampled phase"), you must specify times  within the pss analysis or a number of points within the period and the analysis will provide the sampled noise at those times or time intervals. With knowledge of the slope of the waveforms for the time(s) you specify, an estimate of the jitter can be computed for each.
I hope this helps yumi and I understood your question!
Shawn
Shawn
Reply #5 - Mar 7th, 2023, 10:24pm
I find the terminology used very confusing.  jJtter is always measured at a threshold crossing, whereas sampled noise is the noise sampled at a fixed point in time.  Sampled noise is a voltage or current or some other signal value, not time.  "sampled jitter" is nonsensical, and I don't know why they put parentheses around jitter.  Perhaps that has some significance I do not understand.  I also don't know the meaning of Sampled Phase (or the other choices) and how it relates to jitter.  And what is "1a" sample points? Is it a hexadecimal number? Is it "1 attosamples per period".
It is all very confusing.
