Jul 16th, 2024, 3:40am
MOSFET Symmetry? (Read 12721 times)
Croaker
MOSFET Symmetry?
Dec 12th, 2006, 2:33am
I read a line in Gray & Meyer that the MOSFET is not actually symmetrical in practice.  Does anyone know why?
Re: MOSFET Symmetry?
Reply #1 - Dec 12th, 2006, 6:02am
You might need to provide a little more context.  For example, was G&M saying that actual devices won't be completely symmetric because of their environment?  (well proximity effect, for example)  Or even more basic, the source and drain areas might not be exactly equal in the real layout, because of fingers or diffusion sharing.
Of course, there are also devices that aren't meant to be symmetric, such as some LD- or HV-MOS devices, as well as those with "drain contact pull-back" for ESD robustness.
But G&M may have been referring to something more subtle, such as slightly different channel implants at the source and drain ends such that the saturation current is different when you flip the device around.  I don't know if that happens in real life (or why), or if I'm just making it up.
Croaker
Reply #2 - Dec 12th, 2006, 8:02am
They pretty much just said what I said, without offering any explanation.
I don't see how this is even possible, since there is no indication of the source or drain in a layout...so how could source and drain be manufactured differently?  If you make a MOSFET and interchange the source and drain voltages, my understanding is that it should give the same results.
The most likely thing sounds like it could just be due to imperfections in the manufacturing process.
vivkr
Reply #3 - Dec 14th, 2006, 8:11am
Hi Marc,
There are 2 different contexts where this difference can arise:
1. Most important is in high-voltage devices where the source and drain are designed differently. Typically, the
transistor has a gate which surrounds the source and is itself surrounded by the drain.
2. The ion implantation is done at an angle, which means that the 2 sides of a MOS are not quite symmetrical. This
is to prevent channeling. Now, the problem arises if you treat the right-hand side of transistor 1 as source, and the left
hand side of the other one as drain, and the 2 need to match. Razavi's book on CMOS analog design has some information about
this. I think it is the last chapter on fabrication.
Vivek
Croaker
Reply #4 - Dec 14th, 2006, 9:27am
Regarding 2, who controls which side is the source or drain?
didac
There's a million
ways to see the
things in life
manresa,spain
Reply #5 - Dec 14th, 2006, 12:01pm
Hi.
I think you can't choose which terminal is the drain or source of the transistor. Instead you must use layout techniques to prevent or reduce the asymmetry like using pair of transistors gate-aligned or if you are forced to use parallel-gate transistors try to put dummy transistors in both sides of the pair to try ensure the two transistors see the same environment.(Sorry for my English, I'm from Spain and I'm not very used to write in English).
vivkr
Reply #6 - Dec 15th, 2006, 12:40am
Croaker wrote on Dec 14th, 2006, 9:27am:
Hi Marc,
As didac points out, there is no inherent definition of source/drain in case 2. Consider that different transistors on the very same die will experience this effect very differently, as there is no way of knowing a priori as to which side the ion implantation is done from. Moreover, depending on the orientation of a transistor, e.g. if it ends up seeing the ion beam parallel or perpendicular to its gate, the effect will also vary.
The only solution is to ensure that the direction of current flow is the same for any 2 transistors that must match. Note that this inherent asymmetry often presents a more severe problem than random mismatch. So, you have to lay out your devices very carefully to prevent this problem by choosing source/drain to lie in the same relative orientation for matching devices.
Vivek
mc66
Reply #7 - Jan 13th, 2007, 3:36am
you know when you layout ,you can dram a perfect symmetry MOS device
but when you manufcture it,it's a diffrent story,we can't align two layer exactly as layout,there misalign between
two diffrent layer,so in silicon,there is no really symmetry MOS
eg: In layout the space of cont to poly is same in both S/D,but in silicon,poly align to active,ct align to poly,and
     misalign exist.so there are different space of cont to poly in S/D.
the design rule for guide layout take accout how much misalign of two layer and the cd variation of each layer.
didac
There's a million
ways to see the
things in life
manresa,spain
Reply #8 - Mar 6th, 2007, 2:51am
Recently as I was reviewing "The art of Analog layout" I found a reference to angle ion implantation(which causes asymmetry in MOS drain and source). It explains from a physics point of view so I need to review it carefully. The article its:"Ion Implantation in Semiconductors-Part I
Range Distribution Theory and Experiments",James F.Gibbons. It can be found at the IEEE ieexplore webpage.
Hope it helps
