ee484
Dear all,
What are the mechanisms that cause off-state finite resistance of MOS (i.e., NMOS)?
For example, a simple nmos switch case, is there any charges (i.e., intrinsic or induced charges when one of terminal is at high voltage (i.e.2V)) between source and drain? Can I assume that off-state finite resistance is mainly due to the resistance between two diffusions?
Or, another theory -The mainly responsible for off-state finite resistance of MOS is from the resistance between souce/drain and substrate contact. (Ptap for NMOS case, bulk contact).
any references and comments are welcome.
Last, but not least, can I trust spice for off-state mos model??
Best, B
