Dec 25th, 2024, 1:11pm
Stability in design gain-boosting OP (Read 6802 times)
Monkeybad
Sep 3rd, 2007, 12:22am
Hi! everybody!
In designing the gain-boosting OP, we add another OP to boost the total gain.
How to design this added OP, how much power should I use to save power and keep the stability?
This means where should I place the -3db frequency of the added OP?
I find a paper discuss the gain boost OP
"A Fast-Settling CMOS Op-Amp for SC circuit with 90-dB DC Gain"
It mentioned the stability condition and I don't understand why.
For stability, W3<W4<W6
Could someone explain it? Thanks very much!
BEST REGARD
« Last Edit: Sep 03rd, 2007, 9:35am by Monkeybad »
Monkeybad
Re: Stability in design gain-boosting OP
Reply #1 - Sep 3rd, 2007, 12:41am
The paper
The paper was removed. You can find it in the IEEE Journal of Solid-State Circuits, December 1990 edition. It is titled "A fast-settling CMOS op amp for sc circuits with 90 dB DC gain", and is by Klaas Bult and Govert J. G. M. Geelen.
   -Forum Administrator
« Last Edit: Sep 3rd, 2007, 1:59am by Forum Administrator »
Monkeybad
Reply #2 - Sep 3rd, 2007, 12:43am
gain boost pole
W2 is the -3db frequency of the Aadd,
W3 is the -3db frequency of the Aorig,
W4 is the unit gain BW of Aadd,
W5 is the unit gain BW of Aorig,
W6 is the second dominant pole of  Aorig,
vivkr
Reply #3 - Sep 3rd, 2007, 1:30am
You probably should not be posting a paper which you have not written so publicly. However, to answer your question,
there are 2 loops here, one formed by the main amplifier and the other by the gain boosting amplifier. Both have their
nondominant pole at W6, but have their dominant poles at W3 and W4 respectively. Hence, W6 > W3 & W6 > W4 follow
automatically.
As for W3 < W4, if the gain boosting amplifier has its dominant pole below the main amplifier, then you will have no useful
gain boosting, especially in case you are using it in a switched-capacitor amplifier. You will actually have a slow settling component
due to the pole-zero doublet formed at the lower of the 2 frequencies (W3 or W4).
I am surprised that you should ask this question, because the paper happens to be one of the best written ones with a great deal of explanation
about this very  point.
Anyway, I hope that answers your question.
Vivek
Monkeybad
Reply #4 - Sep 11th, 2007, 7:35pm
Thanks, vivkr
What you mean "the main amplifier"?
Did you mean the total amplifier(after gain boosting) or the original amplifier?
Reply #5 - Sep 12th, 2007, 4:52am
Hi Monkeybad,
The main amplifier means the original amplifier in Klass Bult's paper.
Yawei
