Monkeybad
Hi, aidnaal You can try to use .NOISE ac analyze. The more details you can refer to the HSPICE user manual. It calculates the equivalent noise current multiply the output impedance. Noise currents are due to thermal, shot or flicker noise.
In SC circuit, you can connect the circuit in unit feedback, so the printed result of the RMS noise voltage that HSPICE calculated means the total noise voltage reflected in the output node.
By the way, the flicker noise is proportional to 1/f, when you run .AC analyze, set your lower boundary frequency in the proper value you interested. Or the HSPICE will calculate the unreasonable very large noise voltage because the flicker noise is very high in low frequency. For example, when you design a ADC in 30MHz sample rate, then the lower boundary frequency can set to 30MHz, because in SC circuit the output voltage is changed every 30MHz due to sample and hold action. Only during hold action the SC circuit contributes the thermal noise.
It's just my way to do the noise analyze, correct me if I'm wrong. Thanks!
BEST REGARDS
