udaykumarchintala
ahmedabad
Hi, I have designed a mixer with RF =2.4GHz,LO=2.3GHz as we know the IF is at 100MHz.I got 1 dB compression point of -1.47dBm for this,but I am unable to calculate IIP3 for this in the spectre,I have taken the interfer as 2.41GHz ,for this the third order interferers at the output will be at 140MHz and at 90 MHz,while simulating I am unable to give the arry of indices in the PAC analysis in spectre......help me....
Thanks in advance......
