Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Jul 17
th
, 2024, 10:31am
Home
Help
Search
Login
Register
PM to admin
Modeling
Behavioral Models
› Parallel in serial out(PISO) 8-bit shift registers
Previous topic
Next topic
Parallel in serial out(PISO) 8-bit shift registers (Read 6573 times)
somisetty
Dec 11
th
, 2009, 1:04am
Can anyone provide VerilogA code of parallel in serial out (PISO) 8-bit shift registers.
Thanks inadvance
IP Logged
Re: Parallel in serial out(PISO) 8-bit shift registers
Reply #1 -
Dec 11
th
, 2009, 2:11am
Don't do multiple posts of same contents.
http://www.designers-guide.org/Forum/YaBB.pl?num=1260351750/4#4
http://www.designers-guide.org/Forum/YaBB.pl?num=1259671207/5#5
http://www.designers-guide.org/Forum/YaBB.pl?num=1259647289/0#0
http://www.designers-guide.org/Forum/YaBB.pl?num=1258029179/3#3
If you have Cadence Spectre, see "ahdlLib/parallel_reg_8" and "ahdlLib/serial_reg_8".
You can easily modify it as any function module you want.
Kita━━━━━━(゚∀゚)━━━━━━ !!!!!
http://www7.plala.or.jp/ungeromeppa/flash/kita.html
http://www.youtube.com/watch?v=mjIxGh55bMM&feature=related
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
»» Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
