Jul 16th, 2024, 7:05am
idt () function in spectre (Read 4304 times)
anurag
Mar 07th, 2010, 3:31pm
I am using a behavioral voltage source in spectre to generate desired waveform.
expression : bsource v= idt(v(Vin,0))
with the above expression, I am getting the convergence problem. I tried setting the initial condition from analog design design environment but couldn't resolve it.
I would be thankful if someone could point out the issue with this expression.
Re: idt () function in spectre
Reply #1 - Mar 8th, 2010, 5:34am
anurag wrote on Mar 7th, 2010, 3:31pm:
I don't use bsource much myself, but what about
expression : bsource v= idt(v(Vin), 0)
Note the change in parentheses.
anurag
Reply #2 - Mar 8th, 2010, 8:08am
Thanks for your reply Geoffrey.
idt function takes only 1 argument. In verilog-A, we can give the initial condition by giving 2 arguments in idt function but not in spectre.
I am able to resolve this problem by skipping the dc analysis. I am not sure whether skipping dc will create problem in rest of my circuit or not.
Reply #3 - Mar 8th, 2010, 1:51pm
spectre has been enhanced to allow more than one argument for idt in a bsource expression, and this was added in MMSIM71 ISR9 (in July 2009). I just tried it with the latest ISR, and it works fine.
