Jul 16th, 2024, 11:41am
Problem with ADS MCLIN ! (Read 5681 times)
kennycs
Feb 01st, 2010, 12:28am
When I use S-parameter simulate with MCLIN(differential lines) in ADS, the result |S11|,|S21| seems wrong. I think |S21| should be monotone decreasing ,But the result shows it is  periodic ,I'm confused!
Thanks!
Re: Problem with ADS MCLIN !
Reply #1 - Feb 1st, 2010, 1:41am
kennycs wrote on Feb 1st, 2010, 12:28am:
I think |S21| should be monotone decreasing, But the result shows it is periodic
It is natural result since your line is lossless.
Frequency characteristics of lossless line is periodic.
Why do you think |S21| decrease monotonically ?
Consider |S21| of lossless single line.
Does |S21| decrease regarding frequency ?
For coupled line, if you pay attention to one line, another line acts as resonator.
So periodicity of |S21| is natural.
kennycs
Reply #2 - Feb 1st, 2010, 7:12pm
pancho_hideboo wrote on Feb 1st, 2010, 1:41am:
Thank you very much, I got the reason. Cheesy
