Aug 15th, 2024, 12:23pm
Difference between N/P –select and n/p - active layers in CMOS layout techniques (Read 2635 times)
VINAY RAO
Feb 23rd, 2012, 11:48pm
What is the significance of using n/p select layers along with n/p active layers to make a CMOS active device? Why we need to draw extra n/p select layers though we can distinguish P and N regions just by using P/N active regions?
Vinay Rao.
Re: Difference between N/P –select and n/p - active layers in CMOS layout techniques
Reply #1 - Feb 24th, 2012, 7:29am
This isn't a simulator question.  Perhaps you should have posted it in "Physical Verification, Extraction and Analysis" ?
