This probably depends a bit on the simulator you're using, but spectre has a parameter type on its vccs component. You can make the controlled source a voltage controlled resistor or a voltage controlled capacitor (for example). See spectre -h vccs for more detail. Other SPICE simulators also support similar controlled resistors or capacitors, from memory.
