May 17th, 2024, 5:56am
controllable value (Read 2042 times)
schaedel
controllable value
Oct 24th, 2013, 4:28am
its a long time ago, when i had to use SPICE in school. I WAS able to do things like this. I remember that it wasn't very difficult.
For Simulation i want to control a value (i.e. capacity or resitance) with another input-signal. the paths should be independent. there should only be a control-input (two terminals) an two terminals where between the resistor/capacitor with the controlled value gets connected.
shame on me... everything is forgotten  :-[
Thank you for your Help.
Re: controllable value
Reply #1 - Dec 27th, 2013, 4:55am
This probably depends a bit on the simulator you're using, but spectre has a parameter type on its vccs component. You can make the controlled source a voltage controlled resistor or a voltage controlled capacitor (for example). See spectre -h vccs for more detail. Other SPICE simulators also support similar controlled resistors or capacitors, from memory.
