Aug 15th, 2024, 1:31pm
query of the tstab setting in PSS (Read 4925 times)
donalma
Feb 22nd, 2014, 10:41pm
Hi~
I am testing the  mixer circuit in cadence with PSS to see the spectrum at the output. However , I find that setting 'tstab'  or not make the spectrum quite different .  So, how to explain the difference, and which setting is more reliable? (pictures of the results are saved in the PDF below)
Txs Smiley
Re: query of the tstab setting in PSS
Reply #1 - Feb 23rd, 2014, 3:20am
This should probably be in the Simulators->RF Simulators section, but I expect Ken will move it there anyway.
Looking at the measured markers you've put on the spectrum, there doesn't seem to be any significant difference between the results. Most are much less than 0.5dB difference between all the runs - the bigger differences are those which are a long way down to start off with.
Most of the difference that I could see is around the numerical noise floor. Given that you didn't say what errpreset or tolerances you used, that's most likely to be the major cause of the variation in the smaller signals - changes in input conditions can give different answers which are still within the numerical tolerances you've selected.
Perhaps you could post the analysis and options statements from the bottom of your spectre netlist (the input.scs if using ADE) and that would help understand your accuracy settings?
donalma
Reply #2 - Feb 23rd, 2014, 8:36pm
Thanks for your answering~
The errpreset I use is 'moderate'. I agree with you that the difference is the noise floor,  but I don't know where these noise come from>_<
Here is my input.scs. Thanks for your help Smiley
Best Regard
Reply #3 - Feb 24th, 2014, 2:42am
Having managed to find something to open your netlist (which is in a proprietary archive format; better to use tar), the problem is that you are simulating a 2 tone circuit (13GHz LO with 12GHz RF input) in PSS using harmonic balance, with a PSS fundamental of 100MHz, with 300 harmonics...
pss  pss  flexbalance=yes  oversamplefactor=8  fund=100M  harms=300
+    errpreset=moderate  tstab=800n  annotate=status
Not really a good choice for setup. In general I'd never use PSS in harmonic balance mode with multiple tones (OK for shooting). For a start, the simulation is very slow - and even in this case you're including only 2 harmonics of the LO and RF signals - which isn't very much!
If you simulate with the hb analysis:
hb hb fundfreqs=[13G 12G] maxharms=[5 5] autotstab=yes autoharms=yes
(note that the autotstab came up with a tstab of 3.846ns but actually stopped the tstab after 2.385ns (roughly) as steady-state had been reached. The autoharms came up with 5 harmonics for the first tone. This ran in 1.1s - so was very fast. The results look good to me.
If you're using an older version, you could use qpss (in harmonic balance mode), but if you do, please set the fundname on the two LO signals to be the same - currently you have:
PORT2 (net58 net57) port r=50 type=sine freq=floQ dbm=ploQ sinephase=90 \
       fundname="FLOQ"
PORT1 (net30 net29) port r=311 type=sine freq=frf dbm=prf fundname="FRF"
PORT0 (net28 net27) port r=50 type=sine freq=floI dbm=ploI fundname="FLOI"
Since QPSS works on frequency names, it will see these two as separate. You don't want them to be simulated independently, so give them the same fundname (frequency name) on the schematic - which will mean that QPSS sees two tones. Then set 5 harmonics of each.
The "noise" you are seeing is numerical noise. Because the solvers have to solve equations to within a tolerance, they are not exact - and the tolerance levels will result in a certain amount of numerical noise. Simulating unnecessary harmonics is going to make matters worse.
BTW, I also did try running with shooting PSS - (same unnecessarily low fundamental, and same tstab), and you will also see numerical noise, but it runs somewhat quicker than HB with 300 harmonics (and you're unlikely to be missing anything since the number of harmonics is primarily an output parameter with shooting). Tightening errpreset to conservative does lower the numerical noise floor - but you would have been far better off just having a fundamental of 1GHz...
donalma
Reply #4 - Feb 24th, 2014, 3:34am
Sorry for wasting your time to find the right software.
Your suggestion really help me a lot, thanks you so much!
Best wish Smiley
