Jul 20th, 2024, 12:22pm
How to save digital signal in mixed-signal simulating using spectreVerilog (Read 6815 times)
wendyyang100
May 14th, 2014, 8:15am
I am new to here, and I am doing some analog and mix-mode design now.
I try to save digital signals ( all the digital signal in the design, not just the output of digital part) in the verilog code as follows:
 initial
 begin
  $dumpfile( "wave.vcd");
  $dumpvars( 0, digital);
But I found the saved waveform only have initial value, all that after initialization don't exist.
The analog part works well, and the output of the digital part is right send to analog part. Thus, I guess the fault located in the saving.
How do you save the digital signals using verilog?
How to fix this problem?
Thank your for your patience~
Wendy
wendyyang100
Re: How to save digital signal in mixed-signal simulating using spectreVerilog
Reply #1 - May 18th, 2014, 9:00pm
Please some body reply me how to view the internal digital signal when using spectreVerilog.
Thanks a lot.
Reply #2 - Mar 26th, 2015, 7:03am
Since your saving is done in an "initial" block, why are you surprised that you only get initial values?
wendyyang100
Reply #3 - Mar 29th, 2015, 10:10am
Hi! Thanks for your reply.
In my opinion, the initial block tells the simulator to start dump signals. Not just for the initial moment.
Could you please tell me how do you dump your results?
Thanks for your kind help. I was too happy to find an answer, and found I made a mistake when posting, so I modified this again...
Geoffrey_Coram wrote on Mar 26th, 2015, 7:03am:
Reply #4 - Mar 30th, 2015, 12:00pm
This can be tool specific. Tell us more about your situation.
