Jul 18th, 2024, 12:37pm
÷ (NP+S) divider not working (Read 470 times)
cktdesigner
India
Mar 22nd, 2015, 11:24pm
I am trying to verify the function of a NP+S divider.
I am referring to the divider from Razavi's book shown in the attachment.
In my test-bench all blocks in this NP+S divider are models and no transistor level implementations are present.
In the next few posts, I show schematic of the:
1. NP+S divider
2. test bench
3. ÷2 OR 3 dual-modulus prescaler.
along with the veriloga code for the blocks which I used from this website.
The simulator used is AMS simulator and Virtuoso is IC615.
Now, I will describe the problem I am facing.
In the test-bench the frequency of the input has been set at 14MHz and P has been set to 5 and S has been set to 4.
which => NP+S = 2x5 + 4 = 14
N is 2 since there is a ÷2OR3 dual-modulus prescaler being used.
So the divider as a whole must provide a divide ratio of 14 and hence the frequency of the output of the divider must be 1MHz.
The problem is that the frequency of the output is not at 1MHz but at 1.08MHz which is incorrect.
This NP+S divider does not seem to function correctly.
Please note that I have INDIVIDUALLY checked the functionality of the ÷2OR3 dual-modulus prescaler, ÷P program counter (PC) and the ÷S swallow counter.
All 3 seem to function properly when checked in a stand-alone mode.
I searched extensively about this divider over the web and this forum as well but could not come up with the root cause for the problem, yet.
Could some one please help point out the reason why this NP+S divider is not working?
cktdesigner
India
Re: ÷ (NP+S) divider not working
Reply #1 - Mar 22nd, 2015, 11:27pm
Schematic of the NP+S divider is attached.
cktdesigner
India
Reply #2 - Mar 22nd, 2015, 11:29pm
Schematic of the test-bench
cktdesigner
India
Reply #3 - Mar 22nd, 2015, 11:41pm
Schematic of the ÷2OR3 dual-modulus prescaler along with code for each of the blocks.
This dual-modulus prescaler is taken from Razavi's RF Microelectronics 2nd Edition (p.679, Fig.10.31, Chapter 10, Sec 10.6).
Please note that when MC=0 the circuit divides by 3 and when MC=1 the circuit divides  by 2.
code for DFF:
`include "constants.vams"
`include "disciplines.vams"
module adff (q, qb, clk, d);
output q; voltage q;      // Q output
output qb; voltage qb;      // Q bar output
input clk; voltage clk;      // Clock input (edge triggered)
input d; voltage d;      // D input
real td;
real tt;
real vh;
real vl;
real vth;
integer dir;
real state;
analog begin
      td = 0;
      tt = 1p;
      vh = 1;
      vl = 0;
      vth = (vh + vl)/2;
      dir = +1;
   @(cross(V(clk) - vth, dir))
     state = (V(d) > vth);
     V(q) <+ transition( state ? vh : vl, td, tt );
     V(qb) <+ transition( state ? vl : vh, td, tt );
Code for OR Gate:
module aor (out, in1, in2);
output out; voltage out;
input in1, in2; voltage in1, in2;
real vh;                  // output voltage in high state
real vl;                  // output voltage in low state
real vth;      // threshold voltage at inputs
real td;      // delay to start of output transition
real tt;      // transition time of output signals
analog begin
     vh = 1;
     vl = 0;
     vth = (vh + vl)/2;
     td = 0;
     tt = 1p;
   @(cross(V(in1) - vth) or cross(V(in2) - vth))
   V(out) <+ transition( ((V(in1) > vth) || (V(in2) > vth)) ? vh : vl, td, tt );
Code for AND Gate:
module aand (out, in1, in2);
analog begin
     vh = 1;
     vl = 0;
     vth = (vh + vl)/2;
     td = 0;
     tt = 1p;
   V(out) <+ transition( ((V(in1) > vth) && (V(in2) > vth)) ? vh : vl, td, tt );
The NOT gate in the schematic is realized as a NAND gate with both inputs tied together. The code for the NAND gate inside the NOT gate module in the schematic is shown below
Code for NAND gate:
module anand (out, in1, in2);
analog begin
      vh = 1;
      vl = 0;
      vth = (vh + vl)/2;
      td = 0;
      tt = 1p;
   V(out) <+ transition( !((V(in1) > vth) && (V(in2) > vth)) ? vh : vl, td, tt );
cktdesigner
India
Reply #4 - Mar 22nd, 2015, 11:47pm
Please note that for the ÷P Program Counter the value of "P" is taken as an input DC voltage. (this is temporary just for convenience of use).
Code for the ÷P Program Counter:
module divider2 (out, in, div);
output out; voltage out;      // output
input in; voltage in;            // input (edge triggered)
input div; voltage div;     // div (div ratio input)
integer dir;      // dir=1 for positive edge trigger
                       // dir=-1 for negative edge trigger
real td;          // average delay from input to output
integer count, n;
analog begin
     vh=+1;
     vl=0;
     vth=(vh+vl)/2;
     dir=1;
     tt=1p;
     td=0;
     @(cross(V(in) - vth, dir))
     begin
           count = count + 1; // count input transitions
           if (count >= V(div))
               count = 0;
           n = (2*count >= V(div));
   V(out) <+ transition(n ? vh : vl, td, tt);
cktdesigner
India
Reply #5 - Mar 22nd, 2015, 11:49pm
Please note that for the ÷S Swallow Counter the value of "S" is taken as an input DC voltage. (this is temporary just for convenience of use).
Code for the ÷S Swallow Counter:
module sw_cntr (out, in, div, rst);
input rst; voltage rst;     //rst (RESET input)
integer count, n;
analog begin
     vh=+1;
     vl=0;
     vth=(vh+vl)/2;
     dir=1;
     tt=1p;
     td=1p;
     begin
           count=count+1;
           if ((count >= V(div)))
                 count = 0;
     @(cross(V(rst) - vth, dir))
     begin
           count = 0; // reset count on rising edge of rst pin
           n = 0;
cktdesigner
India
Reply #6 - Mar 22nd, 2015, 11:52pm
Finally here are the actual transient plots for some of the relevant signals of interest.
Note that frequency of output signal is 1.08MHz and not at 1MHz.
I would also like to mention that I have placed the cursors (Both baseline and markerA) extremely accurately right on the rising edges. So the frequency of the output (i.e. pout) is exactly @ 1.08MHz. There is no question of inaccuracy in measurement here.
Reply #7 - Mar 26th, 2015, 7:02am
Please update this post after you've applied Ken's suggestions from your other thread ( http://www.designers-guide.org/Forum/YaBB.pl?num=1426479908 )
cktdesigner
India
Reply #8 - Mar 26th, 2015, 8:52am
Geoffrey_Coram wrote on Mar 26th, 2015, 7:02am:
Hi Geoffrey,
I have already incorporated Ken's suggestion of making tt finite and non-zero. If you carefully note tt has been set to 1psec.
cktdesigner
Reply #9 - Mar 26th, 2015, 9:02am
I recommended that the transition time be nonzero, and that seems to be the case in these models. However, setting tt and td to 1ps will just force the simulator to use small time steps for no purpose, resulting in slow simulations. You should always set td to zero unless you need it, and make tt as large as practical. In this example there seems to be no reason that it should be smaller than 1ns, and could be 10ns or more.
To a simulator, a time point is a 'unit of work'. Change the settings in your waveform views so that it shows the actual time points used by the simulator, then play with you tt settings without changing the period of the underlying signal and see how your choices affect the number of 'units of work' that are needed to render a single edge.
cktdesigner
India
Reply #10 - Mar 26th, 2015, 9:27am
Ken Kundert wrote on Mar 26th, 2015, 9:02am:
Hi Ken,
I actually need to set the input frequency to 2.4GHz. I need to use this divider in a 2.4GHz PLL. This is the reason I set tt to 1ps and td to 0.
For ease of explanation of my problem I chose small values of Fin=14MHz, P=5 and S=4.
My point is that this divider which seems to be a standard circuit and taken out of a popular book does NOT work.
I just wonder how can such a standard circuit given in such a popular book not work?
I am confident that the models are coded correctly. They seem to function correctly on a standalone basis. So, where is the problem?
I thought there are many experts here in dividers and they could easily point out the reason for the incorrect functioning of the divider.
cktdesigner
« Last Edit: Mar 26th, 2015, 10:02pm by cktdesigner »
Reply #11 - Apr 13th, 2015, 10:34am
cktdesigner wrote on Mar 26th, 2015, 9:27am:
I'm not an expert in dividers, but I think they would have the same problem I do: there are a lot of ways you could have introduced a small mistake in the circuit or simulation, and I'm not sure how to verify it without reproducing all your work.
I noticed that your circuit does divide by 13, so I wonder if you try other values of NP+S, do you always get a divide ratio of NP+(S-1), or always NP+3, or something else?  If you do get NP+(S-1), would that point you to the circuit element that is not performing correctly?
