Sep 29th, 2026, 7:00am
Pages: 1 2
Phase Noise or L? (Read 7467 times)
Phase Noise or L?
Nov 05th, 2002, 11:38am
When running SpectreRF's PNoise analysis within Artist, the environment provides a "Phase Noise" button as part of its direct-plot capability. The label on this button is misleading, which has caused a substantial amount of user confusion.
It is important to know that when you press this button you are actually plotting the normalized voltage noise, or L, and not the phase noise (this is why the result has units of dBc). This function was added when we added support for oscillators. Oscillator designers use L as a way of characterizing the phase noise of their oscillators. This works because for oscillators the phase noise dominates, especially close to the carrier, and so they need not distinguish between phase noise and voltage noise. Furthermore, in oscillators the values of L and Sphi (the phase noise) are actually the same in most cases, which adds to the confusion.
However, problems arise when engineers who are not designing oscillators use the phase noise direct plot function thinking that this function is decomposing the total noise into amplitude and phase noise components and plotting only the phase noise. It is not doing that. Rather it is plotting L = Sv(df)/V12, where Sv is the power spectral density of the voltage at an offset frequency of df and V1 is the amplitude of the fundamental. Thus, it is plotting the noise power normalized to the power of the fundamental.
Eugene
Re: Phase Noise or L?
Reply #1 - Nov 5th, 2002, 4:24pm
Hi Ken,
I'm afraid I'm confused now. You say that for oscillators, L and Sphi are the same values. However, In your papers you show L = Sphi/2. Furthermore, if I followed your math correctly,the L in your papers is Sv(df) divided by the *power* of the fundamental (referenced to one ohm), not the square of the amplitude. One thing is for sure: in modeling RF components there are more factors of two than one can shake a stick at and it is hard to keep them straight.
     -Eugene
Reply #2 - Nov 5th, 2002, 8:46pm
Whoops! I spoke too hastily.
Your right, L is Sv(df) divided by the power of the fundamental, and so L = Sv(df)/(2V12)
With L and Sphi, we can both claim to be right. L = Sphi when using double-sided (complex exponential) Fourier representation, and L = Sphi/2 when using a single-sided (trigonometric) Fourier representation.
Good eye, and thanks for keeping me honest.
Eugene
Reply #3 - Nov 18th, 2002, 1:53pm
My work has forced me to revisit this issue again and I am still not I have it straight. Are you sure about the double (single) sided Fourier series explanation? It seems your paper uses the double sideband representation, yet you have
L = (1/2)*Sphi.
Reply #4 - Nov 18th, 2002, 2:08pm
No, I am not convinced I have it right yet either. Let me look into this and get back to you.
Eugene
Reply #5 - Nov 18th, 2002, 3:21pm
While you're at it, it would be great if you could confirm that in your paper, "a" is the double sided density driving the Wiener process and Sphi is a double sided density centered about zero Hz.  Thanks.
Eugene
Reply #6 - Nov 19th, 2002, 5:48pm
Ken,
I found a fairly concise explanation of Sphi and L in Egan's book:
William F. Egan, "Phase-Lock Basics", John Wiley & Sons, Inc.  1998. ISBN 0-471-24261-6,   pages 304-310.
Egan gives a simple example showing that L = Sphi/2  where  L is a single-sided, single-sideband, passband PSD shifted down to baseband and Sphi is a single-sided baseband PSD.
However, as I read Demir's May 2000 Circuits and Systems paper ( at least the part I can follow),
L(fm) ~ 10log10(a*(fc/fm)^2), which differs from your expression by 3dB but perhaps you define L differently.
Now all I need to do is figure out why my code still produces a 3dB error but that is something I must deal with myself.
Eugene
Reply #7 - Nov 19th, 2002, 9:25pm
The strange thing is that while the noisy voltage domain VCO model produces the correct passband, single-sideband, single-sided PSD, the phase-domain "equivalent" produces a single-sided baseband PSD that is shy 3dB.
Eugene
Reply #8 - Nov 20th, 2002, 10:22pm
Ken,
I believe I discovered why the phase domain model seemed to give 3dB less phase noise. I believe the Analog Artist's waveform calculator's PSD function is 3dB off. I checked a simple sinusoid as well as a filtered noise signal. In both cases, the variance of the signal as computed from the time domain waveform was twice the area under the PSD function.
That makes my voltage domain model 3dB high but I think that is probably just uncertainty in eye-ballling the value because the PSD was fairly jagged.
Reply #9 - Nov 21st, 2002, 1:44pm
Have you done anything to compenstate for the noise bandwidth of the window function. For a Hanning window that noise bandwidth is 1.5 bins, which could neatly explain a 3dB difference.
« Last Edit: Nov 21st, 2002, 4:34pm by Forum Administrator »
Eugene
Reply #10 - Nov 21st, 2002, 3:03pm
On the simple test case of white noise filtered by an RC circuit, I compared results using a Hanning window and a rectangular window. The two PSD's were nearly identical and both were 3dB in error. Should the factor of 1.5 also apply to the rectangular window?
« Last Edit: Nov 21st, 2002, 4:35pm by Forum Administrator »
Eugene
Reply #11 - Nov 21st, 2002, 3:09pm
But to answer your question specifically, I did not apply any correction factors for the window function. Is that necessary with the psd function?
Reply #12 - Nov 21st, 2002, 5:08pm
The factor of 1.5 compensates for the equivlant noise bandwidth of the bins, which is dependent on the window function. So for a rectantular window, the factor would not be 1.5, but I don't believe it will be 1 either. I am currently unable to find my copy of Harris, nor can I find it on the web, so I cannot tell you what it should be though.
You can look the number up yourself by finding a copy of
F. Harris. On the use of windows for harmonic analysis with the discrete Fourier transform. Proceedings of the IEEE, vol. 66, no. 1, January 1978.
Eugene
Reply #13 - Nov 21st, 2002, 10:41pm
Thanks for the lead Ken. I'll check it out.
Reply #14 - Apr 1st, 2003, 5:00pm
Eugene,
   There were several places in my phase noise and jitter papers where I was not careful in distinguishing single-sided and double-sided transforms. As a result, there were several factor-of-two errors. I believe I have identified and corrected all of them in the latest versions of the papers, which I uploaded today. Please let me know if you see any further issues.
Pages: 1 2
