Apr 28th, 2024, 1:59am
Shooting Method Question (Read 4440 times)
rickk
Mar 20th, 2003, 5:57pm
I'm trying to build a simulator that can perform a periodic-steady-state analysis using the "plain" shooting method (w/out krylov). I already have a simulator that can perform a transient analysis with reactive and non-linear elements using the backward euler method.
I'm having trouble calculating the Jacobian.  In Kundert et al's papers, there is reference to the C/h+G matrices. However this is assuming the plain nodal analysis approach. My question is this, How do I calculate the Jacobian with modified nodal analysis (MNA) stamps?
skippy
Re: Shooting Method Question
Reply #1 - Mar 23rd, 2003, 5:54pm
The G matrix is the conductance, or di/dv terms.
The C matrix is the capacitance, or dq/dv terms.
h is the time step.
For MNA you would need to swap the rows of your voltage sources with other rows so that you do not have a 0 diagonal element in your Jacobian.
The C/h elements for inductors would probably be something like L/h.
Rodgrigues has a pretty good book
Computer-Aided Analysis of Nonlinear Microwave Circuits
Author: Paulo J. Rodrigues, Artech house, 1997
but its focus is mainly in the frequency domain.
There is also a much older book by McCalla which talks about MNA stamps:
W. J. McCalla, Fundamentals of Computer-Aided Simulation. Boston: Kluwer, 1987.
skippy
Reply #2 - Mar 23rd, 2003, 5:58pm
I have heard that certain aspects of the Shooting Method with respect to the use of iterative methods are patented?  Could someone (perhaps K Kundert) tell me which parts are?
Reply #3 - Mar 25th, 2003, 11:50am
To simplify notation when writing papers I always formulated the methods in terms of nodal analysis with the understanding that the formulation could be extended to MNA by assuming that C is the portion of the Jacobian that is associated with the time-derivitive terms and G is everything else.
There are patents that address the application of Krylov techiques to shooting methods, but none that I am aware of that cover the base shooting methods.
