Jitter Man
Am I? Or am I so sane that u just blew your mind?
Saurabh, Sv of (22) is the power spectral density of the noisy output signal of a free running oscillator. Sn of (35) is the power spectral density of the ni sequence. ni is the sequence that results from samping the output noise of the frequency divider at every threshold crossing.
So your statements are correct, but you failed to indicate that (22) applies to oscillators and (35) to frequency dividers.
