May 4th, 2024, 11:25am
clarification requested (Read 5995 times)
saurabh
Guest
Apr 14th, 2003, 1:36pm
Hi Ken!
I was going through your paper on phase-noise and jitter measurements (the one you update a few days back). Tell me if the equations S_{v} of equation 22 is the same as S_{n} of equation 35.
thanks,
saurabh
  IP Logged
saurabh
Guest
Re: clarification requested
Reply #1 - Apr 14th, 2003, 2:56pm
Sorry for messing up my query. What I wanted to ask was that whether the variables S_{v} and S_{n} represent the same thing in equations 22 and 35 of your paper.
thanks,
saurabh
  IP Logged
saurabh
Guest
Reply #2 - Apr 14th, 2003, 5:17pm
I think I have an answer for my query.
S_{v} is the PSD of the total output voltage noise.
S_{n} is the PSD for the output voltage noise that has been computed at sampled time points using strobed noise analysis of spectreRF.
Is my understanding correct?
Also, how does spectreRF do the strobed noise analysis. Isn't it computationally expensive to do a complete transient noise simulation (even for period T in this case)?
thanks,
saurabh
  IP Logged
Jitter Man
Am I? Or am I so
sane that u just
blew your mind?
Reply #3 - Apr 22nd, 2003, 9:08pm
Saurabh,
   Sv of (22) is the power spectral density of the noisy output signal of a free running oscillator.
   Sn of (35) is the power spectral density of the ni sequence.
   ni is the sequence that results from samping the output noise of the frequency divider at every threshold crossing.
So your statements are correct, but you failed to indicate that (22) applies to oscillators and (35) to frequency dividers.
The Jitter Man
Reply #4 - Apr 22nd, 2003, 10:11pm
The strobed noise analysis is not a full transient noise simulation. You can think of Spectre performing a conventionaly PNoise analysis, with a sampler inserted between the output of your circuit and the input to the noise analysis. If you only ask for one strobe point, the cost of a strobed noise analysis (referred to as a time-domain noise analysis in Artist) is about the same as a conventional pnoise analysis.
