Apr 28th, 2024, 8:39pm
depletion width (Read 4078 times)
Jason_class
Guest
depletion width
Sep 14th, 2003, 5:22am
Hello All ,
May I know why the depletion width for n side of a pn junction is longer than that of the p side?
Also why is the p(x) for n side smaller than that of pside?
Kindly let me know which formula I should refer to?
Thank you
rgds and thanks
jason_class
  IP Logged
Re: depletion width
Reply #1 - Sep 16th, 2003, 3:15pm
Jason -
If the dopant density (which I think you are calling p(x)) is smaller on the n side, then this forces the depletion width to be larger on the n side.  It's simple math: the depleted charge on either side must be equal (at equilibrium), and the depleted charge is the density times the volume.  Assuming equal cross-sectional area, you're left with the depletion width.
As to why n doping is less than p doping, this is process-specific.  One could build an (n)(p+) diode or an (n+)(p) diode, ie, with either side more highly doped than the other.  I don't know if there's a reason that diodes would typically be doped stronger on the p side.
jason_class
singapore
Re: depletion width
Reply #2 - Sep 18th, 2003, 9:05am
Thanks a lot Geoffrey.
You are very helpful
rgds and thanks
Jason
