Dec 14th, 2025, 2:07am
GDSII IP cores (reusable if possible) (Read 3902 times)
sam
Oct 05th, 2003, 11:14am
Hi fellas,
I come from a SC background and I am not fluent in IC design.
So I wonder if I can find an IC layout cell library of Analog/DSP (e.g GDSII files).
Could someone tell me where I could find such IPcores.
Please advise,
Many thanks,
Sam
circuit_master_RT
Re: GDSII IP cores (reusable if possible)
Reply #1 - Oct 26th, 2003, 12:06am
I doubt you will be able to find IP for analog blocks, since analog is not nearly as portable across processes as digital blocks are.   Best bet is to ask the foundry for the process you are considering.
