Dec 16th, 2025, 1:55am
Pages: 1 2
Question about Mote Carlo mismatch model file (Read 8519 times)
uncle_ezra
Re: Question about Mote Carlo mismatch model file
Reply #15 - May 11th, 2005, 10:49pm
How do I vary vth without actually using a voltage source and varying it by delta? Below is what I tried to do but it does not work. What name should I give to subckt?
statistics{
mismatch{
vary vth0mis_n dist=gauss std=3e-3
inline subckt nmos (d g s b)
   parameters w=1u l=1u
   nmos (d g s b) nmos w=w l=l
model n_bpw_33_mm bsim3v3
type=n
+ vth0 = 0.6+dvth0+vth0mis_n/(w*l)
uncle_ezra
Reply #16 - May 12th, 2005, 12:55am
Actually could someone provide a working template for monte carlo simulation.  It would be very helpful.
thanks
uncle_ezra
Reply #17 - May 12th, 2005, 1:37am
So this is the model provided in Cadence help:
library monteLib
section param
simulator lang=spectre
parameters PiRho=2500 PbRho=200 npnbeta=145.5 pnpbeta=200parameters rin1=1000 rin2=5000 rout1=1000 rout2=3000parameters cin=1.7e-08 cloop=1e-09parameters mmstat=1 initstat=1
function Rpb(l,w)=(PbRho*l/w)function Rpi(l,w)=(PiRho*l/w)
endsection param
section stats
statistics {
process {               vary PiRho     dist=gauss std=350               vary PbRho     dist=gauss std=50               vary npnbeta   dist=lnorm std=.9               vary pnpbeta   dist=lnorm std=1.1               vary Rin       dist=gauss std=150               vary cin       dist=gauss std=20p               vary rin2      dist=gauss std=100               vary Cfb       dist=gauss std=.58n               vary rout1     dist=gauss std=30               vary rout2     dist=gauss std=50       }
mismatch {               vary PiRho   dist=gauss std=19               vary PbRho   dist=gauss std=3.75               vary npnbeta dist=gauss std=4               vary pnpbeta dist=gauss std=6       }}
endsection stats
section models
inline subckt npn (C B E S)
parameters brvbe=.6model
mynpn bjt type=npn is=5.771e-17 bf=npnbeta nf=0.9895 vaf=201.6
+ ikf=0.01573 ise=8.976e-18 ne=1.179 br=3.204 nr=0.9944
+ var=27.03 ikr=0.0003047 isc=1.505e-13 nc=1.912 rb=8.706
+ irb=0.001509 rbm=5.833 re=111.8 rc=54.97 xtb=1.5 eg=1.11
+ xti=3 cje=1.983e-12 vje=0.4818 mje=0.2486 tf=0.33e-9
+ xtf=4.359 itf=0.01753 ptf=176.2 cjc=1.749e-12 vjc=0.5989
+ mjc=0.3349 xcjc=0.5 tr=400e-9 cjs=1e-12 vjs=0.75
+ mjs=0.33 fc=0.5 bvbe=brvbe bvce=1
npn (C B E S) mynpn
ends npn
inline subckt pnp (C B E S)
model mypnp bjt type=pnp
+is=1.2e-16 bf=pnpbeta nf=1.00 vaf=26.00
+ikf=70e-06 ise=1.1e-15 ne=2.00 br=13
+nr=1.00 var=10.00 ikr=100e-06 isc=7.0e-15
+nc=2.50 rb=100
+re=15 rc=150 cje=33e-15 vje=740e-03
+mje=330e-03 tf=2.50e-09 xtf=1.00
+itf=2.00e-03 ptf=5.0 cjc=130e-15 vjc=690e-03
+mjc=440.00e-03 xcjc=500.00e-03 tr=5.00e-09 cjs=200e-15
+vjs=590e-03 mjs=440.00e-03 xtb=780e-03 eg=1.200
+xti=1.80 kf=1.60e-15 af=1.00 fc=850.00e-03
pnp (C B E S) mypnp
ends pnp
endsection models
endlibrary monteLib
Where does the name "subckt npn (C B E S)" come from?
Also isnt the model file in a separate file? Can you just modify it???
Reply #18 - May 17th, 2005, 10:24am
jimi
Reply #19 - Sep 6th, 2005, 10:03pm
A working example for TSMC 0.13 um process.
section tt
// add following
parameters avt_nch=0
parameters avt_pch=0
statistics {
  process {
     vary avt_nch dist=gauss std=0
     vary avt_pch dist=gauss std=0
  mismatch {
     vary avt_nch dist=gauss std=4.6
     vary avt_pch dist=gauss std=3.95
inline subckt nch (d g s b)
nch (d g s b) nch_mc w=w l=l m=1 region=triod
include "cl013g_fsg_mc.scs" section=mos
ends nch
inline subckt pch (d g s b)
pch (d g s b) pch_mc w=w l=l m=1 region=triod
// end of jimi's code
ends pch
endsection tt
// then change model name nch in setion mos to nch_mc
The monte carlo works well for m=1, but for m=n, the std is n times instead of sqrt(n), still need some help and feedback to correct it!
Good luck!
xtal
Salt lake city
Reply #20 - Dec 29th, 2007, 5:53pm
I am trying to do a mismatch analysis (monte carlo simulation). I am using the Chartered semiconductor 180nm library using BSIM3v3,
I want to vary the threshold voltage for each transistor in my circuit for each simulation. However, I am getting the same delay for all 20 runs of the monte carlo simulation.
From reading the topic (and also some of the other related topics in this forum), I understand that in order to vary the threshold voltage (device paramater), I need to vary the width/ length of the transistor. Is this correct? or i can vary the threshold voltage directly.
My Library file is like this:
library MyLib
section param                             // I added this section
simulator lang = spectre             // I added this section
parameters vth_variable1 = 1     // I added this section
parameters vth_variable2 = 1    // I added this section
endsection param                      // I added this section
section stats                              // I added this section
statistics {
          mismatch {
           vary vth_variable1 dist=gauss std=0.1
           vary vth_variable2 dist=gauss std=0.1
endsection stats                               // I added this section
section monte_carlo                                             // I added this section
include "sm093001-1k.scs" section=param
include "sm093001-1k.scs" section=ntn_typ
include "sm093001-1k.scs" section=stats
include "sm093001-1k.scs" section=ptn_typ
include "sm093001-1k.scs" section=hdif
endsection monte_carlo                                       // I added this section
section ntn_typ                                                             // section already provided in the library
// model = bsim3
// NewModel =   3
// MetaSoftware Compatibility Mode
// These are BSIM3v3 Model Parameters
// LotName=LOT_NAME UserName=USER Date=03-01-2001
model nmos_1p8 bsim3v3  {
    1: type=n lmin=1.8000000e-07 lmax=0.00000025 wmin=2.19999998807907e-07 wmax=4.39999997615814e-07
+ tnom=25.0 paramchk=1 version=3.2   ......... and all other parmaters
// model = bsim3
// NewModel =   3
//   Typical Models nmos_1p8 ***
    2: type=n lmin=1.8000000e-07 lmax=0.00000025 wmin=4.39999997615814e-07 wmax=8.00000011920929e-07
+ tnom=25.0 paramchk=1.................................and all other paramaters
endsection ntn_typ
Now in this model, there are paramteres defined for each width and length like if i give the width of the transistor as 3u then it picks up the the 4th part in the model ntn_typ
So in the 4th part where vth0 was defined, I changed it to "vth0=0.3340089*vth_variable1".
However, i am getting the same delay in all simulations.
Please help me on this.
Manohar
Reply #21 - Jan 2nd, 2008, 4:52am
xtal wrote on Dec 29th, 2007, 5:53pm:
You can vary the threshold voltage directly; you seem to have done this in your example.
I think there's something wrong with your section set-up.  In your netlist, what is your library statement?
John O Donovan
San Jose, CA
Reply #22 - Jan 16th, 2008, 9:35am
You can vary some model parameters directly on the instance using the following parameters
 delvto   : shift in zero-bias threshold voltage  (default = 0.0)
 delk1    : shift in body bias coefficient (default = 0.0)
 delnfct  : shift in subthreshold swing factor (default = 0.0)
These are valid parameters for bsim3v3 and bsim4
So if you have a model file that defines a model nmos_1p8 as in your example (which contains multiple bins), you could simply do the following
parameter mm_vto = 0.0
statistics {
 mismatch {
   vary mm_vto dist=gauss std=0.1
inline subckt nmos_1p8_mm d g s b
 parameters l w
 nmos_1p8_mm d g s b nmos_1p8 l=l w=w delvto=mm_vto
ends nmos_1p8_mm
m1 1 2 3 4 nmos_1p8_mm l=1u w=0.2u
m2 1 2 3 4 nmos_1p8_mm l=1u w=0.2u
Here you create a mismatch variable "mm_vto", and use the instance "delvto" parameter to directly modify vt0 of the instance. By creating the subckt nmos_1p8_mm, m1 and m2 in the example will have different values for "delvto" during mismatch analysis.
 John
Pages: 1 2
