The factor of 2/3 is a model parameter that can be set in most of Spectre's MOS models. Currently I am away from my desk and cannot tell you the name of the parameter, but if you run "spectre -h model", where model is the type of the MOS model you are using (bsim3v3, etc.), and look at the noise parameters, you should be able to find it easily.
