wolf
First you have to verify by matlab scripts with the same input signal if your 3rd harmonic is a spurious coming from the SD loop. If not, you could verify the linearity of your S&H which should probably be the issue. An unsufficient bw in your ota will more rise your inband-noise than produce harmonics.
