Jul 17th, 2024, 11:19pm
Noise Figure in the LNA+Mixer+VCO (Read 4846 times)
Charles CHENG
Guest
Nov 11th, 2003, 1:32am
Dear all,
     I have tried to use Spectre to simulate the Noise Figure of the the LNA+Mixer+VCO together using the osc. model with phase noise. There are some effect I am not clear. I hope anyone could answer me. Thanks. After the simulation, I have plotted the NoiseFigure and get the NF=7.1dB at 100MHz (I am using RF=1.8GHz and LO=1.9GHz with phase noise). However, there are a small hill at 200MHz in the NoiseFigure plot. If I am just simulating the LNA+Mixer with ideal input LO and RF source. There are no small hill at 200MHz.
     Actually, why there are small hill at 200MHz. Could anyone explain it? I am very thanks for your helping.
Charles CHENG
  IP Logged
BSIM4
Re: Noise Figure in the LNA+Mixer+VCO
Reply #1 - Nov 17th, 2003, 7:36pm
I will take a guess here since more details would help to identify the problem.
The little bump might be caused by the image of the mixer. Why you do not see it with perfect LO? I think it is because with larger steps and a very, very sharp LO, your frequency sweep simply stepped through the peak at exactly 200MHz. When you used a real VCO, reciprocal mixing widened the peak at 200MHz, so you can see it with your current sweeping set-up.
To check if this is true. add 200MHz point to your frequency sweep setup and see if you can see the peak caused by imaging.
Reply #2 - Nov 18th, 2003, 10:18am
The VCO phase noise will modulate all of the harmonics and spurs present in the circuit. So the question is not "why the little hill", but rather, why is there a signal present at the 2nd harmonic of the output signal.
BSIM4 is right to ask about your frequency point selection. Often these little hills exist and are not seen because they fall between the analysis points.
It is not surprising that the output has a 2nd harmonic. In fact if you adjust the frequency point selection, you will probably see little hills at the 3rd harmonic as well.
