The_One
Hi All,
I have a question regarding the fully differential opamp.
for fully differential opamp, how do we measure the slew rate? in single output opamp, the circuit is configured as voltage follower. Then, how about fully differential output? it has two output pin. what configuration should we use?
Thanks.
