Aug 16th, 2024, 1:23pm
RF Filter (Read 4719 times)
Simon
RF Filter
Nov 25th, 2003, 7:14pm
Hello all,
I meet some trouble when I design High pass filters. My target is to tune the filter rejection more than 40dB, at cut frequency 450MHz, and want the slope is  very sharp, about 30MHz.
Is this target viable? What is the best performance at present market? and which compay can provide?
oscilentinc
Re: RF Filter
Reply #1 - May 12th, 2011, 11:30am
Hi Simon, When you try and develop your High Pass Rf Filter you need to make sure that it has the correct impedance level set. check out a list of our RF Filter electronics here http://www.oscilent.com/catalog/Category/rf_saw_filter.htm. also some thing that you might want to check on is the input and output levels too.
pm me if you have any more questions
rfcooltools.com
Re: RF Filter
Reply #2 - May 12th, 2011, 12:31pm
Simon,
You may be able to do this discretely provided that you can get inductors and capacitors with tight enough tolerances and high enough Q.  For example this image is a filter designed with near ideal Q components.
http://rfcooltools.com
Re: RF Filter
Reply #3 - May 13th, 2011, 10:58am
time to get a book on filter design. Zeverev is the classic
http://www.amazon.com/Handbook-Filter-Synthesis-Anatol-Zverev/dp/0471986801
but its out of print - there are others written on the topic too.
As for filter done with high Q components - if you can not get it in the real world, whats the point of designing it in the first place?
rfcooltools.com
Re: RF Filter
Reply #4 - May 13th, 2011, 12:13pm
loose-electron,
Quote:
as for filter done with high Q components - if you can not get it in the real world, whats the point of designing it in the first place?
whats the point? Its a necessary step to understanding the order/ realizability .
You should be saying, "if it does not work with ideal Q components whats the point of designing it with real world components?  "
Even Zeverev uses ideal Q to develop the prototype filter prior to scaling.  Its a necessary step to make an ideal filter then add the reality of self resonance and Q degradation.
rfcooltools.com
Re: RF Filter
Reply #5 - May 13th, 2011, 12:13pm
loose-electron,
