August West
I'll get up and fly away
I think your best bet is to run a long transient simulation to find the steady-state solution, and then save the final state to a file using writefinal. Then on subsequent analyses you can use it as the initial state by using readic. Unless you have a specific reason for doing so, I would not recommend using skipdc. Using it increases the chances of a bad starting point if the circuit is modified in some way. You also have to be very careful to assure that the set of initial conditions you use is consistent with the input signals. In other words, if you use writefinal so save the circuit state when phi1 is high, and then use readic to read it back in when phi1 is low, you are going to get those jumps.
-August
