Apr 25th, 2024, 9:58pm
simulation of fully-differential opamp (Read 4292 times)
chongcw
Guest
Jan 13th, 2004, 11:18pm
i need to design a fully differential opamp using 0.5um tech at a low voltage of 1.2V. the problem is that everywhere i search there isn't sufficient info on designing a fully-differential opamp, especially on low power. i've searched through books, papers and internet. i'm told the problem is that 0.5um is just not feasible to design a low power opamp. can anyone help me?
thanks,
chong cw
  IP Logged
Paul
Switzerland
Re: simulation of fully-differential opamp
Reply #1 - Jan 14th, 2004, 7:59am
Hi Chong,
the technology does not represent a limitation on low power, but on speed. The higher supply in "older" technologies is favorable for low power analog design. On the other hand, if you limit your supply voltage to 1.2V, you lose this advantage and the higher threshold voltages in 0.5 compared to more recent technologies will make your circuit harder to design. You must differentiate "low-power" from "low-voltage". Some people tend to mix these parameters because they are related for digital circuits.
What you must basically do for low-voltage design is to limit the number of stacked devices. The telescopic amplifier is an example of what you should not do for low-voltage design.
The Ph.D. by A.Abo at Berkeley may give you some info on low-voltage design:
http://kabuki.eecs.berkeley.edu/~abo/abothesis.pdf
Some more links on low-voltage design:
http://www.elec.ucl.ac.be/enseignement/ELEC2650/chapter4.pdf
http://www.elec.ucl.ac.be/enseignement/ELEC2650/chapter5.pdf
For low-voltage amplifiers, you can also look for papers written by Steyaert or Vittoz.
Good luck
Paul
