amitava
cincinnati
IIP3 analysis on a netlist with nport statement
Feb 06th, 2004, 11:59am
Hi, I am facing a problem when doing Cadence Spectre simulation for IIP3 analysis on a netlist that has "nport" statements modeling the interconnects of a circuit. As an example I am giving the nport statement of a 2 port network that I have in my netlist below: -------------------------------------------- simulator lang=spectre model sp_data1 nport file="spNport1.data" //Components X1 (a1 a2 b1 b2 )sp_data1 ------------------------------------------- The file "spNport1.data" contains the s-parameters (2x2 matrix) of the interconnects (a1 to a2 and b1 to b2) as a 2-port network. The netlist has other elements like resistors, transistors, inductors and capacitors connected to each other to form an LNA topology. There are other "nport" statements too for other connectivities but I have given an instace with 2 nets connecting a few of the components. When I simulate the entire netlist for doing the IIP3 analysis I get an error like this: ************************************ Error found by spectre during periodic steady state analysis `pss1'. Distributed components and components with hidden state are not allowed with this analysis -- analysis skipped. nport Analysis `pss1' terminated prematurely due to error. ************************************** As pss and pac analysis are essential to do the IIP3 analysis, I am not sure how to avoid this error from happening and to determine IIP3 of a netlist that has "nport" statements describing the interconnects.
(I went thru the designers guide on how to avoid "hidden-state" errors in spectre but am clueless on how to avoid the error in this case)
Can anyone of you help me on this. Thanks and Regards, Amitava
